Chapter #4
That's enough of soldering, now for the easy part.
The soldering part is finally done, and now it’s time to do the mechanical assembly.
Step 14 – The button caps
Pressing those pushbuttons without button caps on would be really tough, wouldn’t it?
Well then, let’s take out all the button caps and place them on the buttons.
Same as with the pushbuttons, there are two types: the bigger ones are for the A and B buttons and the smaller ones make up the rest.
Place them on top of the buttons and push down firmly.
They should make a “click” when they fit into place.
Step 15 – The front casing
Since we don’t want anything to happen to your Ringo, it’s best to put it in its plastic casing.
Let’s start with the front side.
For this, we’re going to need:
6x M3x8mm metal bolt
(WATCH OUT – there are two versions of metal bolts that look similar; you need the shorter bolts here)
6 x M3x5mm brass (golden) spacer
(WATCH OUT – there are two similar types of brass spacers in your kit and you need the bigger brass spacer here!)
1 x Front protective casing
1 x Front aesthetic casing
Put the bolts in from the front side and tighten the metal spacers from the back side.
Don’t tighten them too much, because you could damage the casing!
The front part should look something like this now:
When you put the bolts through the back side, don’t screw down the spacers all the way through.
This will prove useful up ahead when we’ll connect both sides of the casing.
Step 16 – The back casing
Take the rest of the components:
6x M3x12mm metal bolt
(WATCH OUT – there are two versions of metal bolts that look similar; you need the longer bolts here)
6x M3x4mm brass (golden) spacer
(WATCH OUT – there are two similar types of brass spacers in your kit and you need the shorter brass spacer here!)
1 x Bottom aesthetic casing
1 x Bottom protective casing
The process is pretty similar to assembling the front casing.
Step 17 – The battery
The battery comes with pre-applied two-sided sticky tape, so you’ll need to peel off the paper layer from the back of the battery.
Be careful not to peel off the whole tape, just the protective paper layer.
Place it inside the largest slot on the back casing, and make sure the battery’s cable is facing right.
Press down on the battery firmly to ensure it’s stuck to the casing nicely.
After sticking the battery to the casing, all that’s left to do is connect the white connector into the slot on the Main board where it says “battery”.
Step 18 – The antenna
You were probably wondering what’s that dangling black wire connected to the network module.
That’s the Ringo’s antenna and it is impossible to connect to the mobile network without it.
Like with the battery, you’ll need to first peel off the paper layer from the end of the antenna.
Be extra gentle with it as it can be damaged if sticked wrongly!
Then stick it to the casing right next to the battery, with the antenna wire facing up.
Be careful when tugging on the antenna because the antenna connector on the network module is a bit fragile and might even break if you put too much strain on it!
Now you should have the back casing connected to the Main board with the battery and antenna as shown on the photo on the left.
Step 19 – Combining the front and back casing
Place the back casing onto the back of the Main board.
Flip the phone so that the screen is facing up.
Now place the front casing onto the front side of the Main board.
Tighten the six bolts on the BACK SIDE.
Squeeze the bottom and top pieces of casings together with your fingers while tightening the bolts.
Keep in mind that you don’t tighten them too much when assembling the casing because you might damage it.
Step 20 – Placing the stickers on the button caps
Of course, the phone just wouldn’t look right with blank button caps.
So, take out your buttons sticker set and place the stickers on their respective positions.
If you’re not sure which sticker goes where, take a look at this picture for help.
We’ve also included a spare sticker set, just in case.
And voilá, you’ve just assembled your very own mobile phone!
Check out the following chapter for further instructions on how to set up your Ringo.
Time to wrap things up!
Chapter #5 - Finishing touches
Subscribe To Our Newsletter
Join our mailing list to receive the latest news and updates from our team.
You have Successfully Subscribed!
