Chapter #5
We’re done with the assembly process and now it’s finally time to see this thing in action!
Firstly, if you have received a SIM card with your CircuitMess Ringo kit, take it out and pop it out at the 2nd smallest size (micro SIM).
If you didn’t receive a SIM card with your kit, or if you don’t have one that you can use, don’t worry, your Ringo can function just fine without a SIM card (except for calls and messages, duh!).
Still, we advise that you should insert a SIM card if you have one before going further.
The SIM card slot is located on the left side of the device, and you need to insert it so that the notch on the SIM card faces upwards (check the picture).
When inserting it you should hear a click when it sits in the slot.
The Micro SIM slot has a push-push mechanism (push when inserting and push when removing).
NOTE: SIM can be inserted in multiple ways but it will only work if it’s inserted the right way. After inserting the SIM card, restart the phone so that the SIM module can reload the card.
IMPORTANT: Before turning your Ringo on, we recommend charging your phone for at least one hour.
The batteries come discharged in order to preserve their chemical composition.
After it charged for a while, press the ON button on the bottom right side of the phone.
Your Ringo should power on and boot into the Startup wizard.
Follow the on-screen instructions of the startup wizard to check if everything works right.
In case something is wrong or you have any questions about the assembly process, please feel free to let us know at contact@circuitmess.com.
Also, any feedback that you give is extremely useful to us so we can make this guide and the Ringo kit even better.
Your phone is now up and running! Bravo!
So, you’ve built your Ringo…now what?
Building the Ringo is just the beginning.
Don’t let it collect dust in your drawer! Join the community forum, make your phone unique, code a game or an app for it… There are a number of possibilities for what you can do, and we’re still creating new examples, guides, apps, and games for the Ringo.You can start off by checking out Ringo basics tutorial which will show you how to use the phone and its capabilities!
Ringo Basics
Subscribe To Our Newsletter
Join our mailing list to receive the latest news and updates from our team.
You have Successfully Subscribed!
